When I use the color "orange" I always get an error which doesn't occure when I'm using the hex code instead:
The error message is shown in this picture:
The way I use "orange", another color and the hex code is shown here:
In summary it's no problem for me, because I use the hex code - unfortunately it used some time to locate the error.
Capitano
Thanks for reporting this, I've filed a bug report.
This post may be a bit old to see replies, but if you are reading this, probably you faced this error today:
Unhandled exception: TypeError: Cannot set property to '"black"'. Invalid value: Expecting String ('color name' or '#hex') or Nu
Here is how I fixed it.
I was trying to set a background color on my app using ... something like this
let colorBackground ="black";
bg.style.fill = colorBackground;I got the error
Then after reading this page I changed it to something like
bg.style.fill = "fb-"+colorBackground; still no luck , got the similar error (not the same)
there is the catch , after reading it closely I observed 'fb-"black"' extra pair of " double quotes
'fb-"black"' so I wrote a regex to remove extra pair of " double quotes
bg.style.fill = colorBackground.replace(/^"(.*)"$/, '$1');
voila ! it worked. ✌️
