01-14-2019 11:26
01-14-2019 11:26
Can somebody please post a little example for an onreachgoal event (e.g. daily steps)?
Does the Fitbit Simulator allow user activity manipulation so that I will be able to test this?
Thanks in advance!
Best Answer01-14-2019 13:21
01-14-2019 13:21
I don't think you can test in the simulator, but here's a sample:
import { today, goals } from "user-activity";
goals.addEventListener("reachgoal", (goal, evt) => {
if (today.adjusted.steps >= goal.steps) {
// step goal reached
01-14-2019 13:21
Best Answer01-14-2019 14:02
01-14-2019 14:02
Thank you Jon!
Is this event also being fired for active minutes goals, calories goals etc or is it only being fired when the steps goal has been reached?
Best Answer01-14-2019 14:05
01-14-2019 14:05
It's fired for all goals, you just need to determine which have been met.
Best Answer01-15-2019 10:05
01-15-2019 10:05
Thanks, it works perfectly on my Versa!
