01-10-2018 09:22
01-10-2018 09:22
Hello,
When I run my clockface for the first time, I get an extra return from my settings page. The key it is returning is "selection"...which I do not have anywhere in my code. It returns valid information (it returns not-selected items that could be selected) after my settings are incorporated into my clockface. Is the "selection" key something the system creates itself on a first run? The key is not returned at any time after the first start-up of the clockface.
From my console log:
The last bullet should not be there... I am trying to understand what is happening.
Best Answer01-21-2018 10:46
01-21-2018 10:46
I changed my code to rely more on files and this has apparently cleared up the issue.
Best Answer01-16-2018 15:10
01-16-2018 15:10
Did you solve this issue?
Best Answer01-16-2018 17:22
01-16-2018 17:22
I've been on the road and have not been able to work on it. But, at last run the extra line was still there. Any thoughts?
Best Answer01-17-2018 10:05
01-17-2018 10:05
Do you have the project source online somewhere?
Best Answer01-18-2018 16:25
01-18-2018 16:25
Yes...I think. I uploaded into a Github discord, but Github changed the code slightly. The URL is https://github.com/FlyFrosty/Travelers-Clockface. I thought I could post it in the discord, but that appears to be another version of the chat board. If I am wrong and you have another suggestion, I am flexible.
Thanks
01-21-2018 10:46
