You have highlighted a missing feature with the simulator. It does need a manual intervention to values so we can text arcs and bars etc in association with progress of activities.
I found the best way around it is in the simulator, go to settings and change the device and then change it back again, it seems to take the stats back a bit.
Best Answerthanks for your prompt answer
unfortunately I already test this method and notice a little reduction of step and cals but not a rest.
it's the same thing with log out log in.
I hope an update will offer a reset button.
cordialement
Best AnswerI just test it.
It doesn't reset the values.
I try log-out and reinstallation of the exe without results.
Why Fitbit do not add this obvious feature ?
