01-25-2019 10:15 - edited 01-25-2019 10:16
I want to be resliient with the data I send from/to device and companion.
But there is no easy way of track if the message was sent in a lapse of time, because:
* The only communication we have is with callbacks, not promises.
* The error event is not connected to the 'send' action that originated the error, so we cannot easily track the missed messages.
My proposal is:
1. Upgrade the API to return Promise-like responses, instead of unconnected callbacks. This way we can rely on the platform to let us know wether it went ok or not.
2. At least provide the original `data` property of the original `send` action. This will help us to construct the 1. option I just wrote, without creating a complex system of messaging and tracking IDs between both device and companion (that is posible and already done, but too much!).
What do you think?
01-27-2019 11:05
01-27-2019 11:05
My understanding is the the Messaging API provides UDP style communication, while File-Transfer style provide TCP style 🙂
If you want to make sure data is received, use the File-Transfer API.
Have you ever received an error event for a message lost in transmission?
As long as it is possible to create a "complex system of messaging and tracking IDs", I don't think that Fitbit will put resources in improving this.
Getting Promoses based API would be nice... but the communication between the device and the phone is still miserable ... so I would prefer to get a reliable phone to device communication first 🙂
Best Answer02-07-2019 14:02
02-07-2019 14:02
I independently ran into this issue and agree that it's a problem.
I'll add that it doesn't look like the only documented error (BUFFER_FULL) is implemented correctly. When you fill up the buffer by sending a load of messages quickly, you will not see a BUFFER_FULL error event, but instead your app will crash with the error: "Error 12 Critical glue error". Test code for this here: https://gist.github.com/harryeakins/9a5ce6168a474b0849772d475627b3f8
