01-26-2018 10:51
01-26-2018 10:51
I was wondering if there's a way to dynamically fetch a list of data to be used with the onAutocomplete prop for the <TextInput> component inside the settings file?
01-29-2018 02:15
01-29-2018 02:15
Ended up just using fetch in the companion file, then storing the list via settingsStorage to be consumed by the settings page.
01-26-2018 12:32 - edited 01-26-2018 12:32
More Context:
I'm building a cryptocurrency ticker app and I want to allow users to curate their own list of coins they want to keep a watch on. The documentation seems to indicate that all user customization should live inside the settings page. The <AdditiveList> component appears to be what I am looking for. The documentation demonstrates that I should use the <TextInput> component to allow users to add values to the list.
I want to be able to dynamically grab the list of coins to autocomplete from one of the coinmarketcap APIs. It's possible for me to just download this list and statically include it in the app, but given that new coins are added every day, having the ability to dynamically poll for the latest coins seems to be a better approach.
Example user scenario: User wants to track Bitcoin prices. User navigates to the app settings. When the users inputs "B" in the <TextInput> component, it should filter and suggest "BTC, BCH" etc.
01-26-2018 19:43 - edited 01-26-2018 19:44
Hi!
In my crypto app, the coins are hard coded with coinbase as the spot price source.
For your use, you can probably just use a predetermined list of textinputs that a user can add the Coinmarketcap ticker symbol into. That way when you use the tile list widget, you can remove unused tiles. I know there is no way to dynamically create a view, so it limits the choices of the user to the max number of textinputs you make it. There might be a better way though...
01-27-2018 01:23
01-27-2018 01:23
Yeah... seems like the SDK is not fully fleshed out yet. There seems to be a lot of limitations in what you can do.
01-29-2018 02:15
01-29-2018 02:15
01-29-2018 11:38
01-29-2018 11:38
I found that I had to use fetch() like that too.
06-11-2018 19:30
06-11-2018 19:30
To follow up on this, you can indeed use the fetch API in settings and then return a promise with the results you'd like to render. This is what the native Weather app seems to do.
Here's an end-to-end example of what fetching a list of items from an API with bearer authentication might look like:
<TextInput label="Add item" action="Add" onAutocomplete={async value => { const token = JSON.parse(props.settings.api_token as any).name;
const headers = new Headers({
'Authorization': 'Bearer ' + token,
'Accept': 'application/json',
const res = await fetch("https://example.com/api/items", {headers});
const body = await res.json();
return body.items.map(({name}) => ({name}));
Note that the remote server needs to have a CORS policy configured to allow https://app-settings.fitbitdevelopercontent.com (which is kind of annoying -- ideally the Chromium instance would just disable web security so that this isn't needed, psst. Fitbit devs).
