08-25-2022 19:29
08-25-2022 19:29
Hi,
I was wondering if the companion websocket must use wss or if ws works fine. Because previously, I implemented a websocket server(not secured) and connect using the companion websocket and it works. But about one month ago it stopped working and I saw a couple of old post saying it must use 'wss' since android 9.
Any help is appreciated 😄
Thank you
Best Answer08-25-2022 21:44
08-25-2022 21:44
I think you can use ws only to these IPs (through Android).
Best Answer08-25-2022 19:30
08-25-2022 19:30
Previously, I connect using 'ws' instead of 'wss' btw
08-25-2022 21:44
