09-18-2020 09:20
09-18-2020 09:20
After ugraded to OS Simulator 0.8.3, screen events (onclick, onactivate,..) are not working anymore (even trying the sdk-exercise repo) but side buttons events (keypress) are still working. Is it a bug (I'm on Win10)?
So I wanted to go back to Simulator 0.8.2 but I didn't find any link to download an older version... Any idea where I could find it?
Thanks for your help
Best Answer09-18-2020 15:44
09-18-2020 15:44
I am not 100% sure if that link is gonna work however if it is not working, then just let me know and I will upload it somewhere for you:
https://simulator-updates.fitbit.com/Fitbit%20OS%20Simulator-latest-0.8.2.exe
Kind Regards
Dominik
Best Answer09-19-2020 05:16 - edited 09-19-2020 05:17
Hello i faced the same issue. to solve it i unistalled/installed
Best Answer09-20-2020 00:59
09-20-2020 00:59
Thanks for the link, I was able to download it!
Best Answer09-20-2020 01:00
09-20-2020 01:00
Thanks for your help.
Unfortunatly, uninstall/install didn't solved the problem...😞
