Just wanted to report a bug in Fitbit Studio. Every time I have Fitbit Studio running for more than several hours, the Fitbit studio stops running the companion code. This happens every time more or else. When I typically come back the next day or something, the problem seems to go away for a couple of hours and then it is back again.
Do you mean if you leave the simulator running? Does anything appear in the log files when it's failing?
Mac: /Users/<yourusername>/Library/Logs/Fitbit OS Simulator
Windows: C:\Users\<username>\AppData\Roaming\Fitbit OS Simulator\
Best AnswerSo, I am using a physical device connected to Fitbit Studio. After a couple of hours, the app does not even run any of the companion code. I put console.log() in the beginning of the companion code, does not log anything. All the app itself on Fitbit runs though.
