10-01-2017 16:24
10-01-2017 16:24
I tested the Fitbit Studio. it looks good.
But I think it´s better to get more templates for getting experience for building a new project.
Is it possible to intigrate the standard clock faces of the Ionic as templates ?
THX !
10-01-2017 17:11
10-01-2017 17:11
In a reply to my question here a fitbit employee said they would be adding examples and tutorials, but can't share clockface code.
There is a sample LED clockface they have that you can copy though, you might want to check it out.
Best Answer10-01-2017 17:11
10-01-2017 17:11
Best Answer10-01-2017 18:09 - edited 10-01-2017 18:14
I think you mean the digital clockface ?
But there is only the time, no date or step stream etc.
To try and learn how to implement a sensor stream in the face, it would be better to get
a testing clockface wich is more extensive.
I would like to do the same as you discribe in your linked post.
Like changing some things on a existing clockfaces to learn more about it.
Best Answer10-02-2017 05:20
10-02-2017 05:20
Best Answer10-09-2017 10:08
10-09-2017 10:08
My first experience with the studio !
