03-08-2021 08:19
03-08-2021 08:19
So I've tried to get familiar with the Fitbit studio and instantly decided to try out the starter examples. After connecting phone and fitbit (physical) to the fitbit studio, I tried running the app, and I got this error:
Build failed!
Internal error during build. Guru Meditation: [object Event]
My first instinct was to do some research and after trying a few browsers( Google Chrome, Opera and Firefox) I decided maybe it would work if I installed the Fitbit OS Simulator. Turns out it still gave the same error.
After starting from scratch recreating 'fitbit arcular', I also got the same error. I've tried not modifying filenames, as well as changing .defs and .view files to .gui as some sources recommended it so, same result time and time again.
If any of you know what the problem is that I'm currently facing, please let me know.
Thanks in advance,
Andrecator
P.S.: it's also worth mentioning I unchecked the build version of the fitbit sense devices since I'm using a Versa 3.
Best Answer03-09-2021 02:43
03-09-2021 02:43
Ok so for some reason, if you wait a day and then try to build again, it works fine.
Best Answer03-08-2021 11:15
03-08-2021 11:15
Hello @SunsetRunner I've moved your post out of hardware support and into the Software Development Support.
03-09-2021 02:43
03-09-2021 02:43
