04-25-2022 07:14 - edited 04-25-2022 07:15
I used to use a watch face on my Ionic called Flashring. The code was open source and had even been updated and released as Flashring2 (which was even better). Now that the Ionic recall has forced me to upgrade to a Versa 3 I've been looking for the Flashring code with the hope of updating it for the Versa3. Does anyone know where I can find the code for either Flashring or Flashring2? (The only link I can find gives me a 404 Not Found.)
04-26-2022 13:20
04-26-2022 14:38
04-26-2022 14:38
Doesn't answer the question. I'm asking about the code for this specific clock face.
04-26-2022 18:24
04-26-2022 18:24
I found this: https://github.com/PedanticAvenger/FlashCGM but haven't examined if it's what you are looking for. It does claim "...work to alter Fitbit Ionic Flashring Watch Face to support Blood Glucose...".
Best Answer04-26-2022 19:41
04-26-2022 19:41
@golddave - you'll find it here https://github.com/Fitbit/ossapps
04-27-2022 06:39 - edited 04-27-2022 08:34
@Guy_ No, you won't. Did you try clicking the link?
I don't mean to sound snarky but I did an extensive search before taking the time (both mine and yours) to post here. I appreciate the time you took to find that but if it were that easy I wouldn't have asked. A live link is not to be found using Google so I asked here in case anyone knew better.
Best Answer04-27-2022 06:41 - edited 04-27-2022 08:34
@Fabrikisto Thanks. I've been playing with that code off and on for a couple of weeks. The issue is that it's too far removed from the original Flashring code for me to work with (but I'm trying). I've reached out to the developer of that version (before I posted here) but have not yet gotten a reply.
