There are a number of different techniques you can try. You need to make sure your battery saver is OFF on your phone. If it's on, it turns off GPS. You also need to make sure that you have your GPS turned to "High Accuracy" (I think thats only on Android though). You also need to make sure, in the fitbit app, to have all-day sync on, so it syncs automatically.
Best AnswerThe problem are with inspere HR and the Fitbit application. The screen After one minute can't synchronisation and on my Android mobile have the message from Fitbit application (GPS dysconnected with bluetooth). I think my problem come from the application with thé last update or the last update Android.
Thanks for your help
