The Device API reference states that there is a method to return the current display brightness (not an override setting) but I cannot get this to work and cannot find any examples of how it should be used.
https://dev.fitbit.com/build/reference/device-api/display/#displaybrightnessvalue
Does anyone know how to retrieve the current display brightness as set in the device settings?
Thanks!
