I have a basic gradient mask setup where the left side of the screen is HMS and the right is three goal rings with icons. On the simulator, I can see everything perfectly and nothing overlaps. However, when I load the clockface onto my Versa 2, a black rectangle on top of the minutes cuts off part of the hours and a black rectangle on top of the seconds cuts off part of the minutes. See here: https://imgur.com/a/wtOP3Fc. I made a watch with the same spacing but without a mask and there is no overlap at all so this has to be a mask issue. So:
I only have a Versa 2 so I cannot check this on any other watches.
I've simplified it to just the clock. I am using v4.2 and testing on Versa 2. I have the same index, widgets, and utils for both clocks. The index.gui is only different in that I put my hours, minutes, and seconds in a mask tag and added the gradient tag underneath.
index.js
import clock from "clock";
import document from "document";
import { preferences } from "user-settings";
import * as util from "../common/utils";
// Update the clock every minute
clock.granularity = "seconds";
// Get a handle on the <text> element
const _hours = document.getElementById("clockHours");
const _minutes = document.getElementById("clockMins");
const _seconds = document.getElementById("clockSecs");
// Update the <text> element every tick with the current time
clock.ontick = (evt) => {
let today = evt.date;
let hours = today.getHours();
if (preferences.clockDisplay === "12h") {
// 12h format
hours = hours % 12 || 12;
hours = util.monoDigits(hours);
let mins = util.monoDigits(today.getMinutes());
let secs = util.monoDigits(today.getSeconds());
_hours.text = hours;
_minutes.text = mins;
_seconds.text = secs;
}utils.js
export function monoDigits(num, pad = true) {
let monoNum = '';
if (typeof num === 'number') {
num |= 0;
if (pad && num < 10) {
monoNum = c0 + monoDigit(num);
} else {
while (num > 0) {
monoNum = monoDigit(num % 10) + monoNum;
num = (num / 10) | 0;
} else {
let text = num.toString();
let textLen = text.length;
for (let i = 0; i < textLen; i++) {
monoNum += monoDigit(text.charAt(i));
return monoNum;
const c0 = String.fromCharCode(0x10);
const c1 = String.fromCharCode(0x11);
const c2 = String.fromCharCode(0x12);
const c3 = String.fromCharCode(0x13);
const c4 = String.fromCharCode(0x14);
const c5 = String.fromCharCode(0x15);
const c6 = String.fromCharCode(0x16);
const c7 = String.fromCharCode(0x17);
const c8 = String.fromCharCode(0x18);
const c9 = String.fromCharCode(0x19);
function monoDigit(digit) {
switch (digit) {
case 0: return c0;
case 1: return c1;
case 2: return c2;
case 3: return c3;
case 4: return c4;
case 5: return c5;
case 6: return c6;
case 7: return c7;
case 8: return c8;
case 9: return c9;
case '0': return c0;
case '1': return c1;
case '2': return c2;
case '3': return c3;
case '4': return c4;
case '5': return c5;
case '6': return c6;
case '7': return c7;
case '8': return c8;
case '9': return c9;
default: return digit;
}mask: index.gui
<svg class="root" viewport-fill="#000000">
<mask id="mask">
<text id="clockHours" class="Clock-Mask" />
<text id="clockMins" class="Clock-Mask" />
<text id="clockSecs" class="Clock-Mask" />
</mask>
<svg mask="#mask" width="100%" height="100%">
<gradientRect id="gradient" width="100%" height="100%"
gradient-type="linear"
gradient-x1="50" gradient-y1="0"
gradient-x2="100%-50" gradient-y2="0"
gradient-color1="magenta" gradient-color2="red" />
</svg>
</svg>no mask: index.gui
</svg>styles.css
.root {
width: 100%;
height: 100%;
.Clock-Mask {
fill: red;
x: 50%+5;
font-size: 120;
font-family: SevilleSharp-Regular;
text-length: 32;
#clockHours {
y: 17%+42+10;
text-anchor: end;
#clockMins {
y: 50%+42;
text-anchor: end;
#clockSecs {
y: 83%+42-10;
text-anchor: end;
}widgets.gui
<svg>
<defs>
<link rel="stylesheet" href="styles.css" />
<link rel="import" href="/mnt/sysassets/widgets_common.gui" />
</defs>
</svg>Both look fine on the simulator but I downloaded both to my watch to test again and the margins still overlap when using a mask.
Best AnswerI wonder if this could be a font substitution thing. The sim may handle this differently to the watch, and I don't recall that font-family being standard.
Stretching images, or having very large elements, can also result in clipping. At a quick glance, you don't seem to be doing that, but maybe check.
Best AnswerIt's not a font issue as far as I can tell. I can't say I've tested all the different fonts but it does the same thing if I use System-Regular instead of SevilleSharp-Regular and regular or monospace digits.
I don't think I'm stretching anything but idk...
How about setting width/height on the text elements?
Best AnswerI added heights to the text elements in the index.gui but no change. Looking at the documentation, text doesn't have a height attribute (https://dev.fitbit.com/build/guides/user-interface/svg/#text). Textarea does but specifying the height doesn't fix the issue. I am using font-size: 120 but when I clip the height below 132, the text completely disappears both on the simulator and on my watch.
