Hi,
I am trying to get the 'Image Grayscale Magic' to work, but instead of "All the mid-gray areas will inherit opacity according to their depth of color (0 - 255)", all mid-gray areas render completely opaque, making blurs, anti-aliasing not possible.
I have used ImageMagick to create the grayscale PNG:
The resulting PNG gives me this info:
0.png: PNG image data, 58 x 86, 8-bit gray+alpha, non-interlaced
The resulting image looks good when I view it on my computer (different levels of transparency), but has only two levels (opaque/transparent) on the fitbit simulator and on the Versa watch itself.
Anyone know of an example where this does work? What am I doing wrong?
Hello,
This is a really old post, but I was able to get to work fine. Let me know if you are still having an issue, and I can help. I am pretty certain alpha is not supported (the magick algorithm adds it (more black equals transparent).
