01-05-2018 10:06
01-05-2018 10:06
Hi,
Can anyone help me understand what the 6 vibration patterns:
Actually make the motor do?
Specifically, I'm looking for what the pattern of vibrations is in each case.
Thank you!
Matt
01-06-2018 01:09
01-06-2018 01:09
They are documented here:
https://dev.fitbit.com/build/guides/design-guidelines/visual-styles/
Each of the patterns is described.
01-06-2018 01:09
01-06-2018 01:09
10-07-2020 14:38
11-08-2020 07:01
11-08-2020 07:01
Are there new Haptics for SDK version 5?
08-26-2021 00:24
08-26-2021 00:24
You can check the old version of officical guide on the wayback machine.
