11-10-2017 19:35
11-10-2017 19:35
I have found that the Heart Rate Sensor will stop working in two senarios:
Rebooting the watch does not fix the sensor issue.
My current work around is to change watch faces. The watch then seems to reset it's sensors.
Has anyone else had this issues or has this been raised as a bug? Whilst it is hard to replicate, I have experienced this on quite a few occasions.
11-11-2017 18:16
11-11-2017 18:16
Have you tried listening for the onerror event, then stopping and starting the hrm?
Best Answer11-12-2017 17:05
11-12-2017 17:05
The hrm doesn't work for the standard clock faces in this scenario either, so I am not sure that this would help.I will add it to my code anyway, as it cannot hurt
