Hi all,
i developed an app colled fitfortune that is a gui for fortune linux program.
Right now i have asked help to fitbit testing team, but they does not have a solution.
I've updated my app for making it works, and they says that code is perfect, but it does not works.
Can you help me debugging and writing it? You can publish your changes in github and obtain a credits for developer or debugger, as you want.
Thanks in advance.
Excuse me for the vote, i wanted to clicked on reply, please delete it.
I've an idea, but my account is currently under investigation, you can try to declare a function inside the app calling the function of companion ad using setinterval on that function, and see if so it works.
Thanks.
Best AnswerHi all, i think i made id.
It did not have background permission.
Please wait the update on fitbit store, and see if the fortune is showed once.
Best AnswerHi all,
i found https://dev.fitbit.com/build/guides/companion/ on google, right now the app has been modified, but it needs background permission that can be obtained only from fitbit.
You can study the code that is on github waiting for the app.
Happy Hacking 😄
