Within in the companion, you can use fetch() to send a POST request to an https endpoint.
https://developer.mozilla.org/en-US/docs/Web/API/Fetch_API/Using_Fetch
Best Answervar url = 'http://qav2.cs.odu.edu/fitbit/test.php';
var data = {username: 'example'};
function postData(){
fetch(url, {
method: 'POST', // or 'PUT'
body: data, // data can be `string` or {object}!
headers:{
'Content-Type': 'application/text'
}).then(res => res)
.then(response => console.log('Success:', response))
.catch(error => console.error('Error:', error));
setTimeout(postData, 2000);If I Keep this in companion will it work? or it is not working in my end, Can some tell me how to resolve this issue?
Best AnswerHi, I am also facing a similar issue in my companion code, POST request just isn't firing and not getting any errors either, so a blackbox to debug.
I believe this may be an iOS device related issue. I tested my code in companion and on an Android device and it works seamlessly.
@JonFitbit can you provide some information or guidance regarding this please?
