02-15-2018 17:13
02-15-2018 17:13
I've been looking at the SDK examples.
Wished they were a step by step tutorial.
I'm currently yet to familiarize myself with the associated tools and development processes.
Thanks,
IRealTB
Best Answer02-16-2018 02:52
02-16-2018 02:52
The SDK only works with Fitbit OS devices (e.g. Ionic), but you can use the Web APIs to query weight data from Aria. https://dev.fitbit.com/build/reference/web-api/
Best Answer04-13-2018 02:18
04-13-2018 02:18
Hello,
I make an app for fitness clubs. Each member can dowload this app and I would like to retrieve data of Aria 2 on members phones, it's possible ?
Thanks,
Best Answer04-13-2018 02:21
04-13-2018 02:21
@emi1 wrote:
Hello,
Thanks,
Get each user to login to their Fitbit account using oAuth, then query weight data from the Web API. https://dev.fitbit.com/build/reference/web-api/body/
Best Answer04-13-2018 02:46
04-13-2018 02:46
I can't ask every member to create an account on Fitbit.
Could I create a account for each user with the API or synchronize Aria 2 with bluetooth ?
