I'm new to fitbit/dev and am wondering how people build a clock screen with different size texts.
For instance, let's say I want to display the time 01:23:45 but I want each display item (hours, min, secs) to be a different size and placed next to each other.
Would the best way to do this be to create three different Document.TextElement objects, one for each display item, append the ":" as needed, then manually place them in the right place by selecting the appropriate x and y origins in an SVG.text object to reserve the space for each item so that they're placed properly next to each other? In other words, hard-code the placement of each item?
Is there an easy way to find the maximum size of each item? Is this what DOMRect does? So could I make the 2nd element origin based on the size of the text of the first element?
Is '8' the largest digit in each font so if I reserve the SVG.text space for "88" for each element, that will be the maximum extent of that item as the numbers change?
Thanks! Does DOMRect tell me the size of the item?
