So I'm using ngx-datatable on Ionic though it's an Angular thing, and like other such modules there are some hoops to jump through to actually use it on an Ionic app and actually have the assets copied over to www when you build or serve your project.
I have found instructions on this very helpful and recent blog post by Simon Grimm, but they are for Ionic 3 so he uses the "config" property on his package.json and copy.config.js.
These are ionic-app-scripts things and I don't think they work for Ionic 4. Does anyone know how to do this kind of thing with Ionic 4 and Angular 6? I would appreciate any clue.
I do understand that Ionic 4 is a beta release for now, and that YMMV for a while when trying to do relatively convoluted stuff.
Best AnswerSo if your question is not about the Ionic, what is it about? Your post mentions the ionic 4 times plus a few other things.
Are you writing an app for the ionic or do you want to use fitbits API to access your fiFitb bit account.
Hello @jaisonmiguek I've moved your post out of the hardware help and into the SDK board, I believe this is where you wanted to post, let me know if I'm wrong and I can move it.
@Rich_Laue wrote:So if your question is not about the Ionic, what is it about? Your post mentions the ionic 4 times plus a few other things.ShowBox
Are you writing an app for the ionic or do you want to use fitbits API to access your fiFitb bit account.Nox
okay then !
