06-13-2018 08:59
06-13-2018 08:59
I want to create a clock hand with a point and different color on the end. I'm guessing I'll have to create a Rectangle, then somehow add a colored point to the end of the rectangle. Does anyone have an example of doing something like this?
06-15-2018 15:38
06-15-2018 15:38
You can put a few shapes into a single template symbol, then rotate that as a single element.
https://dev.fitbit.com/build/guides/user-interface/svg/#template-symbols
Best Answer06-15-2018 15:38
06-15-2018 15:38
