05-12-2019 00:11
05-12-2019 00:11
I would really appreciate any help that can be given.
I read the followings.
https://dev.fitbit.com/build/guides/settings/
https://dev.fitbit.com/build/reference/settings-api/
https://github.com/Fitbit/sdk-moment
unction settingsComponent(props) {
return (
<Page>
<Section>
title={
<Text bold align="center">
App Settings
</Text>
<Text>sample text</Text>
<ColorSelect
settingsKey="color"
colors={[
{ color: 'tomato' },
{ color: 'sandybrown' },
{ color: 'gold' },
{ color: 'aquamarine' },
{ color: 'deepskyblue' },
{ color: 'plum' }
</Section>
</Page>
registerSettingsPage(settingsComponent);The above code shows the following.
I can select color, but I can not edit text ("sample text").
Please teach how to do it.
Thanks
Best Answer05-13-2019 12:58
05-13-2019 12:58
I think you want the user to be able to edit the text inside Settings, is that correct? For this, use the TextInput component:
<TextInput
label="example"
settingsKey="text"
/>see https://dev.fitbit.com/build/reference/settings-api/#textinput for more info
05-13-2019 08:49
05-13-2019 08:49
Change this line:
05-13-2019 12:58
05-13-2019 12:58
<TextInput
label="example"
settingsKey="text"
05-13-2019 15:35
05-13-2019 15:35
Thank you very much.
TextInput is correct.
It's embarrassing.![]()
