I would really appreciate any help that can be given.
I read the followings.
https://dev.fitbit.com/build/guides/settings/
https://dev.fitbit.com/build/reference/settings-api/
https://github.com/Fitbit/sdk-moment
unction settingsComponent(props) {
return (
<Page>
<Section>
title={
<Text bold align="center">
App Settings
</Text>
<Text>sample text</Text>
<ColorSelect
settingsKey="color"
colors={[
{ color: 'tomato' },
{ color: 'sandybrown' },
{ color: 'gold' },
{ color: 'aquamarine' },
{ color: 'deepskyblue' },
{ color: 'plum' }
</Section>
</Page>
registerSettingsPage(settingsComponent);The above code shows the following.
I can select color, but I can not edit text ("sample text").
Please teach how to do it.
Thanks
Best AnswerI think you want the user to be able to edit the text inside Settings, is that correct? For this, use the TextInput component:
<TextInput
label="example"
settingsKey="text"
/>see https://dev.fitbit.com/build/reference/settings-api/#textinput for more info
<TextInput
label="example"
settingsKey="text"
Thank you very much.
TextInput is correct.
It's embarrassing.![]()
