Hi everyone,
So I found a clock face I absolutely love that is currently compatible with ionic versa and versa 2, but unfortunately the developer has been inactive for about a year now. They provided their files through gitlab so I was hoping it would be relatively easy for me (with no current coding/programming knowledge, but with a strong ability to learn computer related topics) to make it compatible to the Sense since I wouldn't have to come up with the entire thing. Does anyone have any resources on compatibility updates or is this a bigger undertaking than I’m thinking? Thanks in advance for any help anyone can offer!
It's not a huge undertaking, but it will require a bit of willingness to learn. Have a look at the 'Migration' section here.
You can also search here for SDK4 SDK5.
If you decide to use Fitbit Studio rather than CLI, you may find it easier to modify the package.json file before uploading it to Studio.
Moving post to the SDK forums
