07-12-2021 15:15
07-12-2021 15:15
Hi,
I've just started app development and can't figure out how to align an <svg> group I'm using for a symbol & corresponding text. I know text elements can be right-aligned with
text-anchor: end;, but when I tried using that property on the entire group, my Versa 2 just ignored that line and kept rendering with a beginning anchor.
I know it's possible to set up a group with a right-end alignment because my clockface (Fitbit's "Simple") does it, but I'm not sure if you have to check and update the x-position with code or if there's an abstracted way to do it in pure css. Thanks for your help!
Best Answer07-12-2021 15:24
07-12-2021 15:24
There's no general style for right alignment. Most elements (including groups and symbols) have their left edge specified by x. However, you can set x to something like "100%-50" where 50 is the element's width.
07-12-2021 15:24
