I've been making my own clockface since yesterday and testing it on my fitbit versa instead of testing in the simulator. The clock isn't finished yet, but for now I want to change it to a clock face from the ones you can choose.
But it won't work, my self-made clock face is still there. I even deleted the self-made clockface in the fitbit studio and restarted my versa multiple times. I chose other clocks to see if it works. But it doesn't. It shows the fitbit logo and then I see my self-made clock back again..
Who can help me out?
Thankyou 🙂
Best AnswerNot sure if im too late, but i believe you can open the FitBit app on your phone & navigate to the Device you linked to & open the developer Menu... There you should see "Sideloaded Apps" (which i believe are the apps you've built using the developer bridge) which you can delete (uninstall).
I hope this helps
I hope this helps
Thank you for this solution. I found this out a few minutes after posting this post here. But I couldn't delete my post. haha
The first time I used the fitbit, the developer menu wasn't there, so I wan't looking for it on the app. But later on when I scrolled a little down, I saw the developer menu and deleted it there.
