Hey,
I don't understand the example in the API documentation about how to use 3D transformation.
In my example I'm trying to rotate a circle around the x-axis in a 3D-fashion. The basic idea is that it should resemble a spinning coin.
I think I understood 2D transformation quite well up until now, just don't understand, how to achieve this using 3D transformation. I would be very grateful, if maybe somebody can support me with a short snippet of code, or an example using 3D transformation.
Is there a specific API doc that mentions 3D transforms that you are referring to? As far as I can tell, the Fitbit SDK only supports 2D transforms, so you would have to transform your circle into an ellipse to give the illusion of a spinning circle.
Best AnswerThe animations guide mentions 3D Transformation, including rotation.
https://dev.fitbit.com/build/guides/user-interface/animations/
