12-09-2018 09:00
12-09-2018 09:00
Hi... I am unable to connect my Versa device with Fitbit studio... Please help... I am almost at the end of creating my custom clock face....please ....please ....please ..... help me out.
12-11-2018 11:46
12-11-2018 11:46
Do you have any more details about your problem?
You must be logged into Fitbit Studio with the same user account as logged into the Fitbit mobile app.
Then enable the Developer Bridge on your phone: Fitbit Mobile app > Versa > Developer options
Then enable the Developer Bridge on your Versa: Settings > Developer Bridge
Then select the 2 devices inside Fitbit Studio, and install your app.
12-09-2018 09:15
12-09-2018 09:15
12-11-2018 11:46
12-11-2018 11:46
12-11-2018 18:23
12-11-2018 18:23
Thank you JonFitbit for your suggestion and steps. I did finally found out there are multiple WiFi network I use even at home. One with small & long range. In order to connect versa with studio...
Make sure Versa Mobile App, Device Versa & Fitbit studio are connected by SAME wifi n/w
11-09-2019 04:50
11-09-2019 04:50
I have the same problem but on the updated app there is only the developer menu and it connects my phone but not my watch
11-22-2020 09:42
11-22-2020 09:42
I also have this problem. I have fitbit studio on my chromebook and I got it to connect to my phone, but it won't connect to my versa 2. It might be because of my chromebook, but I thought there might be something else that I am doing wrong.
12-10-2020 20:03
12-10-2020 20:03
