07-04-2023 00:43
07-04-2023 00:43
Hello,
I want to fetch health data using Fitbit API. After authentication from app side, What is the right procedure to fetch or call health API. Should it be implemented on our local backend or It should be directly called from App side? Kindly provide overall right procedure to implement fitbit api
Best Answer07-04-2023 00:57
07-04-2023 00:57
It depends which API you want to use. You probably want the Web API, which is the subject of a different forum section.
