06-09-2019 04:38
06-09-2019 04:38
Hello everyone, i try to create an app which uses dropbox (my setup is vscode + cli). Therefore i want to use the dropbox sdk in the companion-part. I have install the npm-package successfully and import the dropbox-object like:
import { Dropbox } from 'Dropbox';
But when i try to build the app i got the following error:
[error][companion] companion\index.ts:3,9 Error: 'Dropbox' is not exported by node_modules\Dropbox\es\index.es6.js Details: code: MISSING_EXPORT url: https://rollupjs.org/guide/en#error-name-is-not-exported-by-module- frame: 1: import { Dropbox } from 'Dropbox'; ^
Because of the lack of documentation how to import a third party library i am not sure if there is more to do. The only thread i found was https://community.fitbit.com/t5/SDK-Development/My-example-of-using-third-party-ES-modules-lodash-re... and here is lookslike i have to copy the source to a special directory?! Hope someone can help, thx.
06-22-2019 12:47
06-22-2019 12:47
Ok,found a solution...if you go to the '...\node_modules\dropbox\package.json', remove the line
'"module": "es/index.es6.js"'.
It looks like it is a flag for bundler like rollup.js to determine which files are used (info-at-stackoverflow).
After that i could compile and get no error if i use the sdk. Hope this will save futher developers some time.
06-16-2019 12:05
06-16-2019 12:05
Ok after lot of trail and error coding, i am a step futher.
I changed the index.es6.js
//uncomment this
// export default { // Dropbox: Dropbox, // DropboxTeam: DropboxTeam // };
//and add this export { Dropbox as Dropbox }
I assume that the dropbox sdk and fitbit uses different version from rollup hence the error. Now i can compile and install the app. But i got the next error 😕
Companion: ReferenceError: babelHelpers is not defined ? at node_modules/dropbox/es/rpc-request.js:153,3 ? at node_modules/dropbox/es/rpc-request.js:129,26
Maybe this time someone here has a clue for me to solve this issue?
06-22-2019 12:47
06-22-2019 12:47
