06-20-2020 00:20
06-20-2020 00:20
Hey guys, so i'm trying to set up my first clockface with kpay but I keep getting the error message "Developer ID must be a valid UUID." I have tried copy and pasting my ID from the kpay package.json and from the fitbit gallery app manager. Is there a different ID I should be using?
Best Answer06-20-2020 00:33
06-20-2020 00:33
Hi!
When you login to gam.fitbit.com and click on one of your clockfaces or apps, you should be able to see the developer Id on top:
That is the one you need to use.
If that still doesn't work you might be putting it at the wrong place? Perhaps it would be easier if you join our kiezelpay discord channel: https://discord.gg/zbqrxh8
That will make it easier to check what exactly is going on and help you get it resolved.
06-20-2020 00:33
06-20-2020 00:33
Hi!
06-20-2020 19:38
06-20-2020 19:38
Thank you! It works now, I was using the wrong ID.
