I wrote Watch app that can receive gyroscope and other sensor data on Versa but when I edit it for Versa 3, I do not see gyroscope data is showing. Is it because Versa 3 does not have gyroscope data or it does have but my code have some issues?
Thank you,
Hello, Who can answer me. Is in the versa 3 or versa 4 a gyroscope available yes or no. In the specs is written yes, in the documentation is no, and in the versa itself, after checking via a script, it states no gyroscope available.
So I'm confused. Is it a yes or no for the versa 3 and 4 about gyroscope. If yes, please inform me how to get gyroscope data available. because now the fit sdk script states that there is no gyroscope.
Thanks in advance
Marcel
Ni @nobtiba - it looks like a code problem or permissions issue. See Gyroscope which might help
Hi @mweusthof - See this summary for the Versa 3
You can't program for a Versa 4.
@mweusthof - are you running your program on the simulator or the watch?
Best AnswerHello,
I'm running the script directly on the watch versa 3. The accelerometer works fine, but the message about gyroscope states not available on this device.
Best AnswerI don't think the Versa 3 has a gyroscope (but Sense 1 does). One way to tell is by selecting 'Swim' in the Exercise app. If it claims to be able to count laps automatically, it has a gyro.
This page doesn't list gyro for Versa 3.
Best AnswerI can confirm that versa 3 does not have a gyroscope sensor, I have tested simply using the code here https://dev.fitbit.com/build/reference/device-api/gyroscope/
I have tested for the other sensors made apps for them and they are ok, so it's really missing the gyro in versa 3.
@nobtiba- this page lists the Versa 3 as having a gyroscope https://www.fitbit.com/global/us/products/smartwatches/versa3#features
Click "see all features & specs" and click "specs"
It may be a bug or an incorrect specification
