05-29-2020 04:48
05-29-2020 04:48
Hi,
i'm looking for a way to read the summazized calories of the day which are logged in the food log.
Is there a possibility without having to use the WebAPI?
Thanks!
Regards
05-29-2020 13:41
05-29-2020 13:41
@Capitano wrote:Hi,
Thanks!
Regards
I think you're looking for the ActivityHistory it lets you look back day by day or minute by minute, it's useful though it does have its limits.
Best Answer05-29-2020 23:19
05-29-2020 23:19
Thanks @morningReign , but as far as I see there I find only calories burned. I'm looking for a possibility to get the calories someone logs manually in the food log.
Regards
Capitano
Best Answer05-29-2020 23:32
05-29-2020 23:32
I think it's gotta be Web API.
Best Answer05-30-2020 10:16
05-30-2020 10:16
@Capitano wrote:Thanks @morningReign , but as far as I see there I find only calories burned. I'm looking for a possibility to get the calories someone logs manually in the food log.
Regards
Capitano
Apologies, didn't understand what you were looking for.
I have actually looked into accessing the food log for an app still in the planning phase, and @Gondwana is very correct, you do need to access the food log using the web API.
On a positive note, accessing web APIs is very well supported in the Fitbit OS.
herzliche Grüße
Best Answer06-01-2020 10:59
06-01-2020 10:59
Thanks to all.
Regards
Capitano
