10-20-2020 17:24
10-20-2020 17:24
I've this code that reads the Hearth rate sensor with the frequency of a seconds, with a batch of 300 readings.
Now, for some reason when the batch value is set to that I don't get any event in my Versa3. Instead, lowering it to 250 (or maybe a bit higher, but I've to test) is enough to get the HR events.
So, is there a limit on the batch value we should be aware of?
11-16-2020 05:40
11-16-2020 05:40
Can you check memory usage while you're doing that?
Best Answer11-17-2020 04:20
11-17-2020 04:20
Ok, will do... What's the estimated consumption for that amount of samples?
