10-12-2017 05:08
10-12-2017 05:08
It appears often that the companion app is not ready to receive a message request and nothing is returned when queried. I understand that it will happen again at a later time due to my setInterval checking the weather every half hour, but is it possible to keep trying to get a response from the companion app? That is, using a loop until it returns something? Otherwise, my app starts and nothing is returned for the weather, then the user will have to wait half an hour before getting the weather info. Or will the continual running the function and messaging queries use too much resources?
I have console log files for the watch app along with the companion app. At times, I see logged "Sending query to companion app" and nothing happens (companion app is not ready yet?).
Best Answer10-13-2017 19:21
10-13-2017 19:21
It seems my problem may be due to messaging.peerSocket.onopen often not executing. If I keep reinstalling the app from Studio > RUN, eventually it works.
Best Answer10-13-2017 20:26
10-13-2017 20:26
My experience is that the first time I run, it works.
Then it progressively gets bad, and I have to run it 2, then 3, then 4.5.6 times.
Until I decide to close the project, reopen it, reconnect everything and again we go...
Best Answer10-13-2017 20:33
10-13-2017 20:33
Yeah. It's a bit annoying during dev, but so long as this is not the final user experience, I'm okay to keep retrying. I have an idea that once it's worked once it'll keep going, but if it doesn't work the first time it never will.
I have my code set up to retry the connection test every 10 seconds but the socket is never ready if it isn't the first time.
Best Answer10-14-2017 03:24
10-14-2017 03:24
A few things:
If you're coding a clock face, switch it to an app in package.json, then when you install, if the companion doesn't start, try exiting the app on the device, then launch it again. Does the companion start then?
Thanks!
Best Answer10-14-2017 03:45
10-14-2017 03:45
Android 7.0/Galaxy S8
Fitbit app: v 2.59 (2193184)
Will try the App thing and get back to you.
Best Answer10-14-2017 04:12 - edited 10-14-2017 04:14
I now get "Error installing app". "Build failed" and in Build Messages "Wipe color must be a valid hex color".
Never mind. Found where to set that.
Best Answer10-14-2017 04:36
10-14-2017 04:36
I am on a google pixel with Oreo (8.0.0)
I am developing as an App. As described before, first time is perfect, then it deteriorates the messaging behavior. The companion starts, opens the connection, but it won't send the message through. I close the app on the watch, and run it again. Sometime it takes a few tries. As a watch face seems to work better.
I coded using the code on the messaging guide.
Best Answer10-14-2017 05:03
10-14-2017 05:03
I have a lot of console logging going.
Here's the sequence I should see:
App Started (studio log)
Sending WEATHER command to companion app
Sent it
Weather request received in companion app
Querying openweather...
Received data from Companion app
Temperature is 18C
> Then it sets that onscreen
Second time I reinstalled the code as an App instead of Clockface:
App started
Socket not ready!
Sent it!
In the next 14 minutes, I did not see "Sending WEATHER command to companion app". This log appears in this function:
// Listen for messages from the device
messaging.peerSocket.onmessage = function(evt) {
if (evt.data && evt.data.command == "weather") {
// The device requested weather data
console.log("Weather request received in companion app");
queryOpenWeather();
}So, the companion app doesn't seem to receive the command.
I've never seen messaging.peerSocket.onerror function execute.
I added extra logging to test with now.
Next test, it worked after a 10 second retry gap.
Next test:
App started!
Socket not ready!
Sent it!
Received data from companion app
Switching to clockface app.
App started
Socket not ready!
Sent it!
No log of "Weather request received in companion app" happened at all. Gave up waiting after 12 minutes.
Installed again as app. Worked immediately.
[22:33:32]App Started[HOST] [22:33:32]Loaded and evaluated: file:///android_asset/bootstrap.js[HOST] [22:33:32]Loaded and evaluated: file:///data/user/0/com.fitbit.FitbitMobile/app_companions/5ba2f384-49f5-413b-a0a1-f23a5d36c350/0x0bb996420db45379/companion.js[HOST] [22:33:32]Socket not ready!common/weather.js:21 [22:33:37]Sending WEATHER command to companion appcommon/weather.js:15 [22:33:37]Sent it! :Dcommon/weather.js:19 [22:33:38]Weather request received in companion appcompanion/index.js:64 [22:33:39]Latitude: -31.901818 Longitude: 152.4449007companion/index.js:16 [22:33:39]Querying openweather...companion/index.js:21 [22:33:39]MAINTEMP=291.15companion/index.js:33 [22:33:41]Received data from Companion appcommon/weather.js:38 [22:33:40]The temperature is: 291.15common/weather.js:28 [22:33:40]UNITS.temp= C : UNITS= 18
Hope that helps!
Best Answer10-14-2017 05:16
10-14-2017 05:16
This log may help as well:
[23:14:56]App Started[HOST]
[23:14:57]Socket not ready!common/weather.js:21
[23:15:02]Socket not ready!common/weather.js:21
[23:15:08]Socket not ready!common/weather.js:21
[23:15:12]Socket not ready!common/weather.js:21
[23:15:17]Socket not ready!common/weather.js:21
[23:15:19]Loaded and evaluated: file:///android_asset/bootstrap.js[HOST]
[23:15:19]Loaded and evaluated: file:///data/user/0/com.fitbit.FitbitMobile/app_companions/5ba2f384-49f5-413b-a0a1-f23a5d36c350/0x0c9102c280738c10/companion.js[HOST]
[23:15:23]Sending WEATHER command to companion appcommon/weather.js:15
[23:15:23]Sent it! 😄common/weather.js:19
[23:15:23]Weather request received in companion appcompanion/index.js:64
[23:15:24]Latitude: -31.9018439 Longitude: 152.4449236companion/index.js:16
[23:15:24]Querying openweather...companion/index.js:21
[23:15:25]Cond=803companion/index.js:33
[23:15:26]Received data from Companion appcommon/weather.js:55
[23:15:26]The temperature is: 291.15common/weather.js:28
[23:15:26]Conditions=601common/weather.js:32
[23:15:43]App Closed
Best Answer10-28-2017 03:55
10-28-2017 03:55
I can't get it to detect the peer socket open at all any more. None of my apps can communicate with their companion app. It's very frustrating.
Currently testing by having it retry every 5 seconds but it never opens so the command can never be sent:
// Request weather data from the companion
export function fetchWeather() { console.log("Fetching weather");
if (messaging.peerSocket.readyState === messaging.peerSocket.OPEN) {
// Send a command to the companion
messaging.peerSocket.send({
command: 'weather'
} else { console.log("Peer Socket closed *sigh*")
setTimeout(fetchWeather, 5 * 1000)
}[21:49:55]App Started[HOST] [21:49:55]Fetching weathercommon/weather.js:8 [21:49:55]Peer Socket closed *sigh*common/weather.js:14 [21:50:00]Fetching weathercommon/weather.js:8 [21:50:00]Peer Socket closed *sigh*common/weather.js:14 [21:50:06]Fetching weathercommon/weather.js:8 [21:50:06]Peer Socket closed *sigh*common/weather.js:14 [21:50:10]Fetching weathercommon/weather.js:8 [21:50:10]Peer Socket closed *sigh*common/weather.js:14 [21:50:15]Fetching weathercommon/weather.js:8 [21:50:16]Peer Socket closed *sigh*common/weather.js:14 [21:50:21]Fetching weathercommon/weather.js:8 [21:50:21]Peer Socket closed *sigh*
Best Answer10-28-2017 03:56
10-28-2017 03:56
The companion app Status is always either Inactive or Unavailable. What causes this? It may be the issue.
Best Answer12-05-2017 22:37
12-05-2017 22:37
I'm suffering this problem too. Firmware 27.30.5.16, Android Fitbit app 2.62.1.
It almost seems as though a pool of connections is getting exhausted because individual connections are not being closed when they're no longer required. This would explain the gradual but inconsistent deterioration.
Best Answer12-06-2017 04:34
12-06-2017 04:34
My companion seems to never refresh data. I have three apps doing the same thing (with the same code) and they all are showing inconsistent behavior
