Changing the fill attribute on a rect element works fine:
if (data.colorBackground) {
bGround.style.fill = data.colorBackground;
}But I cannot find an equivalent for changing a gradient-color[1/2] attribute of a gradientRect element:
bGroundGrade.style.gradientColor1 = data.colorBackground;
}Produces: Unhandled TypeError: Cannot set property 'gradientColor1' of undefined
Meanwhile,
bGroundGrade.gradientColor1 = data.colorBackground;
}doesn't throw an error, but neither does it change my background gradient color.
Any help would be appreciated, thanks!
Hey, I'm going through the same thing and will definitely find an answer somehow. I'll let you know what I discover, if anything. Do you have any idea how to change the viewport-fill of an SVG by chance? Pretty similar problem.
Try:
bGroundGrade.gradient.colors.c1 = data.colorBackground;
I decided that I can just use a rect across the entire background and change its .style.fill property instead.
