I have code that uses file-transfer at the beginning of its launch to retrieve a JSON from my server. The JSON is retrieved instantly when I use the Fitbit Simulator, but takes ~5-30 seconds while running on an actual Fitbit Iconic. The JSON is ~500 characters long.
I'm pretty sure that the retrieval process is working and I believe that file should be on the watch - Looking at my console:
[8:54:20 PM]Transfer of 'habits.json' successfully queued.
[8:54:25 PM]/private/data/habits.json is now available
App's code:
// Event occurs when new file(s) are received
inbox.onnewfile = function () {
var fileName;
do {
// If there is a file, move it from staging into the application folder
fileName = inbox.nextFile();
if (fileName) {
console.log("/private/data/" + fileName + " is now available");
} while (fileName);
When I try to read the JSON while using my actual ionic watch I get the following error:
[8:54:30 PM]Unhandled SyntaxError: JSON string parse error.
When I use the Fitbit Simulator the code works flawlessly.
I'm receiving the error on the first line below:
let text = readFileSync("/private/data/habits.json", "json");
console.log(text);
habitsJSON = text;
VTList.length = habitsJSON.length;Am I missing something? Is this a bug in the ionic watch that doesn't exist within the Simulator?
My Firmware version is: 27.32.10.15 and it doesn't saw that I need to update.
One additional error I seem to be getting at the start of the app on both the Simulator and Watch: [8:53:54 PM]Error 22 Invalid value 'Start'
Thank you,
-Don
Thanks for the response and sorry for my delay.
I have not tried CBOR encoding, but the JSONs are really small in size, so I'm not sure what CBOR will buy me?
I placed the repository on gitHub: https://github.com/RocketMan1988/HabitTracker.
-Don
Best AnswerAny news on this. Ran into the same issue: Parse is working on simulator, but not on Ionic.
Can you post the JSON?
