05-04-2018 17:46 - edited 05-04-2018 17:46
My index.gui:
<defs>
<symbol id="symPropeller">
<g pointer-events="visible" transform="translate(50%,50%)">
<image x="$-20" y="$-20" width="40" height="40" href="propeller.png" load="sync" />
<animateTransform attributeType="rotate" begin="enable" from="0" to="1080" begin="click" dur="2" easing="ease-in-out" final="restore" />
</g>
</symbol>
</defs>
<use id="symPropellerInstance" href="#symPropeller" width="100%" height="100%" />
</svg>My app/index.js:
let symPropellerInstance = document.getElementById("symPropellerInstance");
symPropellerInstance.animate("enable");...and the animation doesn't happen. I've even pasted in exactly what I've seen others say works for them, and I don't get any animations triggered by Javascript.
Also, if I add something like:
symPropellerInstance.groupTransform.scale.x = 100;
I get a null reference error. I know the "use" is working because the image is displayed statically.
Can anyone help me? Testing on actual Versa with iPhone X.
Best Answer05-05-2018 12:17
05-05-2018 12:17
This is fixed. I had both a begin="enable" and a begin="click" on the image. Works fine now, although I'm really not sure why none of the other examples I tried worked for me.
05-05-2018 12:17
Best Answer06-07-2018 11:41
06-07-2018 11:41
I am facing same thing. Null reference error. How did you solve it?
