I've been having a very hard time getting two elements of a watch face to display with one overlapped on the other. It is for Versa Lite, and I am using a png background image and two custom font elements using Fitfont. I've tried using the layer property in index.js, re-ordering the elements in index.gui, and I've also tried encapsulating the font elements in a g container and assigning layers. I still can't seem to get it to work. All I'm trying to do is get the background image displayed with the custom font elements displayed over it. Any thoughts?
It sounds like maybe a positioning issue. Try removing the image and making sure the text is positioned correctly first.
Then it should just be
<svg>
<image ...> <!-- bottom -->
<text ...>
<text ...> <!-- top -->
</svg>
I've sent you an email.
