11-05-2018 12:52
11-05-2018 12:52
My clock sends a message to the companion every 15 minutes to check on the current time zone (the horrible solution to how do I check the current time zone. (This is that thread https://community.fitbit.com/t5/SDK-Development/Force-companion-to-pass-info/m-p/3010132#M6532). The problem is limiting to how often this happens. My granularity is set to "minutes", yet this thing seems to be running continuously. loadInfo(myOptions) calls a file on the tracker to populate myOptions which is used to then display the multiple parts of my clock face, including the current time zone.
clock.granularity = "minutes";
//loadInfo calls from files to load clock -line 409 clock.ontick = () => loadInfo(myOptions);
Here is my current fill-in for a solution. It runs over 40 times in that 0.5 Seconds and is part of my main clock display function.
//Force a new timeZone from the companion
if (mins == "00" || mins == "30" || mins == "15" || mins == "45"){
let secs = today.getSeconds();
if (secs < 0.5) {
if (messaging.peerSocket.readyState === messaging.peerSocket.OPEN) {
messaging.peerSocket.send("event");
};Thoughts?
Best Answer11-05-2018 14:34
11-05-2018 14:34
I've just tried it here, and it's ticking on minutes.
import clock from "clock";
clock.ontick = (evt) => {
const now = evt.date;
if (now.getMinutes() % 15 === 0) {
console.log("do it!");
} else {
console.log("don't do it");
Maybe change the syntax of your ontick declaration?
let myOptions = {
blah: "test"
ticker(evt, myOptions);
function ticker(evt, options) {
console.log(options.blah)
} else {
Best Answer11-05-2018 13:07
11-05-2018 13:07
Have you considered setInterval()?
The issue with clock.ontick (as far is I know) is that it will not actually fire when the display is off. Will fire one the display gets on, and at the start of every minute in your case.
Best Answer11-05-2018 13:58
11-05-2018 13:58
It shouldn't be ticking that often with the granularity set. Are you sure you aren't setting the granularity elsewhere?
You can use modulo to check every 15 mins:
const now = new Date();
} else {
it's true that setInterval() runs even if the display is off, but it will also effect the battery usage.
Best Answer11-05-2018 14:20
11-05-2018 14:20
Jon...I did a search for the word "granularity" in ALL my files and it only appears the once. Your method, while prettier, causes the check to run for a solid minute, once again apparently ignoring the clock.ontick. I was thinking I might be missing something with the operation of the clock.ontick function. Apparently not?
Zolika...I actually only want the clock to update every minute. I do not display the seconds on my clock.
11-05-2018 14:34
} else {
let myOptions = {
blah: "test"
} else {
Best Answer11-05-2018 16:25
11-05-2018 16:25
Thank you for working with me on this. I modified my code a bit.
if (today.getMinutes() % 15 === 0) {
} else {
}The "don't do it" part only executes once per minute which leads me to believe that it may be my peerSocket line.
Here is the companion code that gets executed...
//Send the time zone back to the tracker
messaging.peerSocket.onmessage = () => {
console.log("peerSocket called");
sendTZ();
};function sendTZ() {
let myTZ = new Date().toString().match(/\(([A-Za-z\s].*)\)/)[1];
let data = {
key: "zoneCode",
newValue: myTZ
console.log(`full date ${new Date()}`);
console.log(`newValue ${data.newValue}`);
sendVal(data);
// Send data to device using Messaging API
function sendVal(data) {
messaging.peerSocket.send(data);
}I get hundreds of the
Hundreds. As in, enough to bog down my mac's browser. Thoughts?
Best Answer11-05-2018 16:33
11-05-2018 16:33
I notice you're not checking the data in the onmessage event in the companion.
messaging.peerSocket.onmessage = (evt) => {
console.log(`peerSocket called: ${JSON.stringify(evt.data)}`);
//sendTZ();
Are all of these containing your message "event"?
Best Answer11-05-2018 16:51
11-05-2018 16:51
I only send the message so that the companion will send the time zone back (your recommendation). I never send any other information to the companion from the tracker. So, "event" is a random string I probably stole from the sample and has no value to me.
Best Answer11-05-2018 16:54
11-05-2018 16:54
I'm just interested to see if you were perhaps receiving other messages from elsewhere in the code. Do you have the entire project online somewhere?
Best Answer11-05-2018 16:57
11-05-2018 16:57
Ha. I literally just finished copying all my files to github. I think I did it correctly.
Best Answer11-05-2018 19:07
11-05-2018 19:07
If I use
if (Date.now() % 900000 < 100) {
} else {
}I only get 3 returns. So, that it is better but it does not explain why it is executing more than once to begin with.
Best Answer11-06-2018 00:15
11-06-2018 00:15
I've checked your project here using the simulator and I'm only seeing the tick event every minute.
If you're testing on a real device, try deleting the app from your phone/device and rebooting both. Then see if the tick is still happening every second.
In other feedback, I don't think you want to be doing this every minute: https://github.com/FlyFrosty/Traveler/blob/master/app/index.js#L417
You should read the options from the files only once.
Best Answer11-06-2018 09:01
11-06-2018 09:01
I will assume that it is a glitch in the Fitbit OS Simulator then.
I also corrected the file call issue (insert face palm here). And the same error in my other clock face (insert double face palm here).
Thank you for your help.
