06-08-2018 07:34
06-08-2018 07:34
Hello,
I am looking to create an app or watch face that can report the following...
60% of my maximum heart rate for 1 hr (if this is true report it using an alert)
70% of my maximum heart rate for 30 mins (if this is true report it using an alert)
If possible I would also like to do kcal burn rate reporting...
Example 300kcal/hr (if true report it)
I am unsure the best approach for this so hopefully you guys/gals will have some examples or resource links I could steal! 🙂
Thanks for your time,
Steve
Best Answer06-30-2018 17:53
06-30-2018 17:53
Well I do some work with heart rate percentage with my CooperTime (StripesTime on Github) watchface. In my case I was using it to convert heart rate to "rpm" but the math is the same for you. You can then keep track of how long it stays above a specific %.
The kcal/hr would probably be web api + math.
06-30-2018 07:49
06-30-2018 07:49
I don't think you'll find anything which has your exact requirements. The Moment sample demonstrates heart-rate, heart-rate zone, and resting heart-rate.
https://github.com/Fitbit/sdk-moment/blob/master/app/simple/hrm.js
It also demonstrates the activity data
https://github.com/Fitbit/sdk-moment/blob/jonb/fixstats/app/simple/activity.js
You'll need to track this data over time yourself though.
06-30-2018 17:53
