Hey everyone,
for an application I need a more or less continuous stream of accelerometer data. I want the app to run all the time so I use a clockface. My approach is to use an accelerometer with 20 Hz and a batch size of 20 (so every second there's a readout).
Whenever the accelerometer has a readout, I message it to the Companion.
My problem is that the messaging seems to be very slow. So when the Companion received the first package, 5 more were sent. This leads to the unpleasant situation that I send 5 times more data than I receive. When the clockface crashes, all unreceived packages are lost.
I am really out of my wits and very grateful for any ideas.
Best
Simon
Can you provide some code for your project? What format data are you sending?
It might be worth using an approach like this: https://www.npmjs.com/package/fitbit-asap
Best AnswerHey Jon,
sorry for the late reply. Got stuck in something... . I changed my sending strategy such that now I have a send/received ratio of 2/1 when I am constantly sending data from device to Companion. I am sending JSONs which I later forward to a web API.
I attach some code and thank you very much in advance for input.
Btw. the asap package is awesome, thanks for sharing it.
Cheers
Simon
#### APP ####
import asap from "fitbit-asap/app" import { me } from "appbit"; import { Accelerometer } from "accelerometer"; import { Gyroscope } from "gyroscope"; // Disable app timeout if (me.appTimeoutEnabled) { console.log("Timeout is enabled. Disabling it!"); me.appTimeoutEnabled = false; // Disable timeout } else { console.log("Timeout is disabled. Nice!") } // sensor settings const samplerate = 20; const batch = 20; const settings = { frequency: samplerate, batch: batch }; // initialize sensors let acc = new Accelerometer(settings); let gyro = new Gyroscope(settings); // norm function for sensors function getNorm(x, y, z) { return Math.sqrt(Math.pow(x, 2) + Math.pow(y, 2) + Math.pow(z, 2)) } // aux sender function function send(data){ // asap is more stable messaging // https://www.npmjs.com/package/fitbit-asap asap.send(data) }
// will later be sent to Companion var send_array = {}
// serves as message ID var counter = 0 acc.addEventListener("reading", () => { // initialize sending objects var data = {}; data['endtime'] = new Date().getTime(); for (let index = 0; index < acc.readings.timestamp.length; index++) { data[acc.readings.timestamp[index]] = getNorm(acc.readings.x[index], acc.readings.y[index], acc.readings.z[index]) }; send_array['a'] = data } ) gyro.addEventListener("reading", () => { // initialize sending objects var data = {}; data['endtime'] = new Date().getTime(); for (let index = 0; index < gyro.readings.timestamp.length; index++) { data[gyro.readings.timestamp[index]] = getNorm(gyro.readings.x[index], gyro.readings.y[index], gyro.readings.z[index]) }; send_array['g'] = data send_array['ID'] = counter.toString() send(send_array) counter = counter + 1 send_array = {} } ) acc.start() gyro.start()
#### COMPANION ####
import asap from "fitbit-asap/companion" import * as messaging from "messaging"; import { me as companion } from "companion"; // to upload var uploadArray = [] // append incoming data to postData asap.onmessage = function(evt) { const message = evt.data; // print chunk ID console.log('Companion: Receiving ' + message['ID']); uploadArray.push(message) if (uploadArray.length == 30 ){ console.log('Got ' + uploadArray.length.toString() + ' seconds') // upload to API const formData = new FormData(); formData.append('name', 'New Approach ' + message['ID']) formData.append('json_string', uploadArray) fetch('https://my_api_adress', {method: 'POST', body: formData}) uploadArray = [] } }
