Hi,
The following page (https://dev.fitbit.com/build/guides/design-guidelines/ui-components/) describe 9 possible postion for a mixed text yes this other reference only mention 6 (https://dev.fitbit.com/build/guides/user-interface/svg-components/text/#mixed-text).
I can confirm all the mixed-text-right-XXX are not working
Can you either update the doc to reflect there are only 6 avaialble or, even better, implement the missing right ones ?
Thanks 🙂
I made the following pollyfill made from the existing left and center vertion to use while the SDK is updated or the documentation corrected :
<defs>
<link rel='stylesheet' href='/mnt/sysassets/widgets/mixed_text_widget.css'/>
<!-- Left and top aligned mixed text widget -->
<symbol id="mixed-text-right-top" type='mixed-text' focusable='false' pointer-events='none' system-events='all'>
<var id="ufs_header"/>
<var id="dfs_header"/>
<var id="ufs_copy"/>
<var id="dfs_copy"/>
<!-- Top padding -->
<svg id="top-padding" class='top-align-top-padding'/>
<!-- Header -->
<use id="header" href='#dynamic-textarea' class='mixed-text-textarea mixed-text-header' overflow='visible'>
<set href='#text' attributeName='text-anchor' to='end'/>
</use>
<!-- Space in between -->
<svg id="space" class='mixed-text-space'/>
<!-- Paragraph Copy -->
<use id="copy" href='#dynamic-textarea' class='mixed-text-textarea mixed-text-copy' overflow='visible'>
</use>
<!-- Bottom padding -->
<svg id="bottom-padding" class='top-align-bottom-padding'/>
</symbol>
<!-- Left and middle aligned mixed text widget -->
<symbol id="mixed-text-right-mid" type='mixed-text' value='1' focusable='false' pointer-events='none' system-events='all'>
<svg id="top-padding" class='mid-align-top-padding'/>
<!-- Header -->
</use>
</use>
<svg id="bottom-padding" class='mid-align-bottom-padding'/>
</symbol>
<!-- Left and bottom aligned mixed text widget -->
<symbol id="mixed-text-right-bottom" type='mixed-text' value='2' focusable='false' pointer-events='none' system-events='all'>
<!-- Header -->
</use>
</use>
<svg id="bottom-padding" class='bottom-align-bottom-padding'/>
</symbol>
</defs>
It add the mixed-text-right-top, mixed-text-right-mid and mixed-text-right-bottom variation.
