12-29-2019 16:42
12-29-2019 16:42
Hi Fitbit Community,
I'm experimenting in my development environment with the Multi View SVG files functionality, available on the SDK 4.0. I've found these three examples on GitHub that use it:
First example, the official one from Fitbit: https://github.com/Fitbit/sdk-multi-view
Second example: https://github.com/gaperton/ionic-views
Third example: https://github.com/SergioMorchon/fitbit-views
As far as I know the way we have to develop for specific devices was for example, use something like: index~300x300.gui for Versa and index~348x250.gui for Ionic. Now with the Multi View SVG funcionality, I don't think we can use this technique anymore. Correct? I'm thinking about rely on the css file, so styles~300x300.css for Versa and styles~348x250.css for Ionic. The question that I have is, what is the correct approach when using the Multi View SVG functionality and do you want to target specific devices?
Thanks in advance,
12-30-2019 05:26
12-30-2019 05:26
You can still use multiview when building for multiple devices.The resolution suffixes are stripped, so in the case you cite, using replaceSync with `index.gui` will select the right file for that device. The suffixes are stripped at build time resulting in a bundle of files per device.
Best Answer12-30-2019 06:20
12-30-2019 06:20
Thank you!
