01-22-2018 07:00 - edited 01-22-2018 07:08
First time post here in the fitbit community. I couldn't find anything on the forum though for my issue.
Every time I build and run a clockface I am programming, the build succeeds but no matter what the code is, all that is output is a red screen. From then on, I have to reset my fitbit to factory default because I cannot do anything but see the red screen as my clockface. I cannot change it back at all.
This is very frustrating as I have a time limit for this project. If anyone could help, I would greatly appreciate any advice or help you have.
Best Answer01-22-2018 07:19
01-22-2018 07:19
I'm by no means an expert, but if you are following along the initial stuff from fitbit, then you probably have
#background {
width: 100%;
height: 100%;
fill: red;
}in your style.css file. If you have red font, too you might be looking at a blank screen. When I crash my Ionic I get the fitbit logo.
01-22-2018 07:19
#background {
width: 100%;
height: 100%;
fill: red;
Best Answer01-22-2018 07:26
01-22-2018 07:26
I am no expert either so it is my fault I missed that css code in there. Thank you very much.
