10-28-2017 09:13
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-28-2017 09:13
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
Obviously big things are not a good idea for memory, but new style ES style imports are all about being able to be used anywhere and hopefully the treeshaking works.
https://github.com/kencaron/fitbit-os-redux-clock
Here's what I did. I installed redux into an empty directory using npm and copied over it's `src` into a new dir in Fitbit Studio `common/modules/redux@3.7.2`. The 3.7.2 is just to keep things straight in case I really want to do a manual update.
In my `app/index.js` I tried to import Redux's createStore and got it working with
import { createStore } from '../common/modules/redux@3.7.2/index.js';
To get the build to run I just tried to solve all of the missing path errors. For instance in `common/modules/redux@3.7.2/createStore.js` there was a line that imported "lodash-es/isPlainObject".
I made a lodash-es dir and copied individual files over from the local npm project's node_modules until it stopped complaining.
This is not an ideal workflow and would not be practical with a large library, but I can see it being very helpful for people to know how to import lodash into their project.
Next step is to try to build the app in in a clean way with a proper dir structure: actions, reducers, etc.
Yes this is all very academic and may beg the question of "but why?" especially without the index.gui being able to support anything react like. But I'm learning redux and thaving fun with the Ionic so I thought I'd share.
10-30-2017 07:13
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-30-2017 07:13
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Thanks for the post. This (working with the Ionic) has been a good exercise in rethinking my tendency to rely on libraries to solve problems, as the limited space causes you to really evaluate how much "fluff" is included in most libraries.
Did you happen to pull down the app package after the tree shaking to see how well it worked?
10-30-2017 07:50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
10-30-2017 07:50
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
@BayssMekanique Absolutely. JS is a double-edged sword here with the ever expanding size of web-apps.
The final `app.js` from download my app seemed to be 8kb and did seem to shake out quite a bit. For instance no reference to redux's applyMiddleware which I didn't import but it sitting there in my common/modules/redux dir.
In my simple example, introducing Redux increased my JS memory (as read from system.memory.js) by about 13% over a minimal app that simply logs "hello world".
For it's small size and limited dependencies, Redux seemed like a good candidate for an experiment like this. I'd be curious to see what other new "modular ES" libraries work well. date-fns comes to mind for people that need moment.js type stuff. Warning though. I advise against dragging a dir like that into studio with dozens of subdirs and files. I crashed chrome. Try to only import what you really need.
