No developer settings for app or Charge HR
Hey there
I want to use the Fitbit SDK for integrating my Charge HR into my home automation system. So far so good. I read the manuals and there was written I just have to log in into studio.fitbit.com, activate the developer bridge settings in my fitbit mobile app and then I should be able choose my android and fitbit device in the fitbit studio.
The point is, when I navigate to the advanced settings in my fitbit mobile app, there is no developer settings or developer bridge option, also if I open the settings from my Charge HR.
Are there no developer settings for Switzerland or Charge HR?
Thanks in advance.
Kind regards
3 REPLIES 3
The Charge can't run user-developed software. The best you can do is to use the Web API, and you don't use Fitbit Studio for that.
Peter McLennan
Gondwana Software
As @Gondwana wrote, you cannot build app for the Charge HR: only for devices using Fitbit OS, like the Ionic and Versa. Web API is probably the way to go if you want to do any type of integration.
Hey @SunsetRunner ! I'm in a similar boat - I'm about to purchase a Charge, but I'd like to play around with my data in python. If I get a Charge, will I still be able to do the web integration? Specifically, I'm interested in my REM data.
